跳转到主内容
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 个问题 查看全部
There is sound but Does not show any picture
Hv 40” LED smart tv, was working well but now there is no picture at all, full black screen, no light but good sound with able to channel change properly, volume change properly. My 2 yrs old kids used remote that time & after that it happened…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@najmul41bmtc
remove teh back of your TV and disconnect the cable from the main board to the power board. Now turn your TV on. The backlight should be showing. If it is not, you are having trouble with either the power board or the LED backlight array. If the backlight does show you are most likely having issue with either the T-con board or the main board. Post some good pictures of all of your boards with your question. That way we can see what you se. Use this guide 在已经存在的问题里加入图片 for that
这个答案有帮助吗?
得分 1
添加一条评论
Try shining a flashlight at the TV (get close up) and see if you can see a faint display, if you can then your backlight LED’s have gone bad and you have to take your whole TV apart to get to them. Cheap repair in some cases (model dependant).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Najmul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 82
