跳转到主内容
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
54 个问题 查看全部
Passenger windows switches don't roll down or up my windows?
All passenger windows switches won't roll down or up only drivers side can make them go up or down??
While rolling either down or up and one of the passengers switch gets pushed it stops the window…?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
2个回答
最有帮助的答案
Could be the window lock switch “WDO LOCK”
It could be faulty or even simply pressed without you knowing.
I hope this helps.
这个答案有帮助吗?
按维修分数 1
添加一条评论
If the window lock is not the problem, check your wiring where it goes from the body to the driver’s door. There is a wire from the driver’s window switch to the rest of the switches in that harness. Many times I have found that wire broken or shorted.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Vettel seb 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 33
