跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Error 51 iPhone 7 after restoring
Good day,
A customer of mine had his phone updating however he unplugged the phone accidentally while it was being updated. Now, when i put the phone in dfu mode and restore. Its giving me an error 51. I am aware that this is a board related issue. However, can anyone advise if they experienced this issue so that I can know weather it is the NAND or BBCPU or whichever may be the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Try restoring the phone using 3Utools. Hopefully that works.
If not then I'm sorry to say it's probably the NAND needing to be reprogrammed.
Try getting it restored at an apple store as it could be your computer having issues communicating with the phone properly with iTunes etc.
这个答案有帮助吗?
得分 2
添加一条评论
it sounds like the IPSW file format is corrupted. the customer might have run a beta or jailbroken version of iOS which can usually be 1 of many reason for error 51
delete the existing saved IPSW in the iTunes directory
for Mac
  1. Launch Finder
  2. Click Go from the menu bar
  3. Scroll down and click ‘Go to Folder’
  4. Type in “~/Library” and click Go
  5. Click and open the iTunes folder
  6. Open the iPhone Software update
  7. Delete the.IPSW files
for Windows
  1. Go to C:\Users\Your Computer Name\AppData\Roaming\iTunes\iPhone Software Update
  2. Find the.IPSW file and delete or you can press CTRL +A (control all) and hit the delete on your keyboard.
  3. Update the iPhone again.
  4. trying an update after this procedure should force iTunes to download a new file format
try downloading a fresh IPSW image currently Apple only sign 11.4.1 and Proceed to update the iPhone
hope this works if that doesn’t work. you might wanna give FoneDog toolkit IOS system recovery a try
cheers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MICHAEL JABARI NELSON 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
