跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
869 个问题 查看全部
iPhone 8 was stuck at 1% now won’t come on.
So I got a phone with a report from one of my techs. The report said after a battery change the phone was stuck at one percent, thinking it was a defective battery she changed it again and now the device will not power on. Screen tests fine, batteries tests fine, charging port tests fine. I trust the tech to be honest and I did find an answer for the “Stuck at 1%” issue. I looked at the component the post directed me to and it was pulled from the board but I also noticed another chip that was broken. A silver like chip just to the left of the RV3C002UN chip by the battery connector port. I can’t find what component this is without a schematic and I cannot find the schematic. Could anyone help me find the name/number of the silver component?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
In general, a shiny glass component is usually a diode or a MOSFET. Check the screen capture of the iPhone 8 Plus schematic below. There is very little difference between regular and plus models on the basic circuitry.
这个答案有帮助吗?
得分 2
3条评论:
Thanks, I really appreciate it. I’ll look into it as soon as possible and let you know if I can find it.
完成的
So i believe it is a TVS but I dont want to post the number/name of the component until I am %100 sure that’s the component that was damaged. Customer is becoming anxious, not sure if I will still have the phone by the time the part comes in. Very fine time limit I am working with lol
Thank you so much for the information and schematic but I do not want to mislead anyone. Will have to update you when it is confirmed. I do apologize.
完成的
Were you ever able to identify the name of that shiny glass component?
完成的
添加一条评论
添加你的答案
Blaked89 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 562
