跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2050 个问题 查看全部
iPhone 7 Defective Replacement Screen Possibly?
I replaced the cracked screen on my iPhone 7 with a replacement one from iFixit this weekend. The colors were a little less vibrant right off the bat, but were pretty close. No accessibility settings were on. I tried using accessibility settings to get the reds to look more red but to no avail. Today the screen changed to a grayscale only display. I have tried rebooting the phone multiple times, ensuring no accessibility settings are enabled.
I think I may have gotten a defective replacement screen and am bummed that I am going to have to break the seal and replace it again for the phone. That was not easy or fun.
Are there any other non-invasive troubleshooting steps I can perform? When I do enable the accessibility settings and hype out the color/tint I can get the grayscale to be tinted but there is no underlying color.
Please help…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Hi Daniel, [br]
[br]
Have you checked that the display accommodation setting is set to off, when a screen fails it does not normally go greyscale, it normally has lines running either vertically or horizontally.
完成的
添加一条评论
2个回答
已选择的解决方案
Hi All,
Cool update here. There is another setting under ‘Accessibility’ -> ‘Zoom’ -> ‘Zoom Filter’ where one of the options is grayscale. This turns the whole phone to grayscale when zoomed (three finger tap). My phone was somehow changed to zoom at a really low zoom level and that setting was set on. There is no way to see why the grayscale is set this way unless you stumble on this! Maybe they could put an alert if this is set and you are monkeying around with any of the color filter controls.
Thanks for suggesting things David and Minho. The screen is still lackluster in color, but I will take that up with iFixit. Maybe they can give me another one to try with more vibrant color. Thanks again for the suggestions.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Please contact iFixit support. We are just volunteers helping people fix their stuff.
As an aside, whenever you replace a screen, it’s always a good idea to test everything out before sealing it with adhesive. Sometimes the screen can be bad (as you saw).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
danieljseta 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 57
