跳转到主内容
The Moto E4 Plus—also known as the, XT1774, XT1775, XT1776 or Moto E Plus 4th Gen—features a large 5.5" HD display and smooth metal design. Equipped with a 5000 mAh battery, a water-repellent coating, and fingerprint reader.
31 个问题 查看全部
I dropped my phone in a hot tub and now the touch screen won't work
I dropped my phone in a hot tub but I quickly took it out, it worked fine but in the morning when I turned it on the touch screen wouldn't respond at all. Should I just get a new phone or can I just replace the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
unfortunately you now have a water damage device. the instance you removed it from the hot tup you need to remove your sim, battery and dry it with blow dryer or place in rice
disassembling the first layer after the battery would even be better to allow the liquid to dry off quickly
the screen istopped responding to your touch because the water has reach the lego point where the screen, lcd and touch panel is connected to the motherboard soon the screen will start twitching and go blank
best bet now is to do what I advice in the first paragraph for any hope
good luck
cheers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lenny mac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 1,902
