跳转到主内容
The HP 15 laptop can be identified by the model number R263DX.
My laptop screen won’t display anything it’s blank
My laptop starts up smoothly there are no bleeping sounds but the caps lock LED light keeps flashing? Any suggestions on what’s wrong or how i can fix this? Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Try rebooting your system using function + F5 if nothing happens.
Remove battery and then switch on the laptop using charger connected without battery.
Switch off laptop remove battery disconnect power cable and press power button and hold for 50 seconds and then restart the system and check
这个答案有帮助吗?
得分 0
添加一条评论
Hi this is Nolan, I had the same problem and it’s actually quite simple to fix. I need to know how many times your caps locked led is blinking. If it is three times then you do not have enough RAM (system memory) installed. The laptop needs at least 4 gb of RAM to run properly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
NicoleGitonga 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 157
