Replacement LCD Works, Digitizer Doesn't?
Hi All
I am in the process of repairing a customers Surface Pro 4 LCD.
During the removal of the broken LCD I accidentally damaged the digitizer cable, so i ordered a replacement online.
The replacement LCD arrived yesterday (from a different supplier) and works perfectly as an LCD, however the digitizer / touch screen doesn't work at all.
I have double checked the connections coming from the replacement digitizer multiple times and have transferred the N-Trig digitizer circuit board from the original broken screen.
I am convinced that everything is plugged in correctly and was wondering whether the digitizer cable replacement could be faulty?
I have successfully repaired a Pro 4 before , and the LCD panel has come from the same reputable business that sold me the previous one (however on that repair i didn't need to replace a damaged digitizer cable)
I welcome any possible suggestions. Unfortunately as it’s a customers laptop I can’t do a operating system reinstall at the moment to see whether that resolves the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
