跳转到主内容
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
71 个问题 查看全部
Why is my right trigger always activated even when i'm not pressing it
My right trigger has been like this for a year now i am going to open it up once i get the tools and i am wondering if anyone knows what is wrong and how to fix it.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If the right trigger is faulty . When you open it up , you will notice that the trigger makes contact with part of the board ,it may be spring that the trigger makes contact with maybe faulty or maybe need to be cleaned out .if u do open it up try n use 99% alcohol to clean it out of it is messed up . Also the part the trigger makes contact with may be going bad especially if it acting with out you touching it.
这个答案有帮助吗?
得分 1
1条评论:
Would Lysol Disenfectant spray work?
完成的
添加一条评论
最有帮助的答案
What I do is hit the RT or the faulty button really hard with my hand and after a few times, it worked. Not that I necessarily recommended this as the problem does come back occasionally. Do this at your own risk
这个答案有帮助吗?
得分 2
1条评论:
Wtf i just gave it a shot and it actually worked, thank you ive been tryna open it and I don't got the torx screwdriver I was looking around for a bit then I decided to look online and boom seen this and I gave it a wild shot and it actually worked like wtf so many controllers I got rid of I could've just done that😂
完成的
添加一条评论
添加你的答案
Bailey Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 32
过去 7 天: 146
过去 30 天: 626
总计 11,373
