跳转到主内容
修复你的物品
维修的权力
配件 & 工具
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5067 个问题 查看全部
Wi-Fi, GPS and cellular reception bad
So my iPhone 6 has REALLY bad Wi-Fi and cellular service. Recently, GPS also became weak.
My question is: If I fix the Wi-Fi will that fix the other problems?
Or is the cellular antenna unrelated to the Wi-Fi antenna?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
最有帮助的答案
The iPhone 6 had a signature fault with severed/broken traces under/near the broadband CPU. It would cause issues like “searching for service” and GPS issues. I would recommend taking it into a 3rd Party repair shop that specializes in microsoldering. Even if it does not require microsoldering, the techs that do it will know how to test components and verify if it is this issue or not.
This is , of course, just a guess based on the amount of phones displaying this issue that I’ve seen. Without seeing the phone in person, its impossible to diagnose.
Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
If you are just having reception/antenna issues then check out the antenna that is on the back of the logic board near the top. It snaps on at three spots, pretty sure one of those spots is wifi and the others are something else—you could look it up on the schematic. See if it is loose.
somewhere on my youtube channel i fixed a low signal wifi issue on iphone 6 by resoldering a torn connection on that antenna.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aa Aa 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 39
