iPhone always reboots after 3 min of use, NO IMEI, NO BLUETOOTH [...]
¤ Solution found : it was the battery which was at the end of it's life. More details below (just change it)
^= Click on this
Details : The battery was at the end of its life , it couldn't bring enough power to the baseband chip.
█►► IMPORTANT : ◄◄█ == After replacing the battery you'll need to flash the BB to 06.15 again or if you had stock BB then do a simple restore
__________________________________________________________________
Hi, I just bought a used 3GS from Ebay , it was stuck on Recovery Loop , I fixed it.
But then when I started to use the phone , after 3min of use , it will restart by itself. No matter the firmware (tried many versions + jailbroken/non jailbroken ...)
I think it's an hardware issue , what do you suggest me to do ? (I already took it apart , visually seems OK , all connectors are there ...)
Noticed that it will also reboot by itself in recovery mode too but not during restores
ADDITIONNAL INFO : No matter if it's plugged or not , the reboot problem occur
Didn't notice but the baseband seems corrupted 06.15 failed , wifi greyd , bluetooth too . I'll try changing the battery but it might be baseband corruption causing the phone to reboot .
The corruption is software , I might be able to fix it ?
- Random reboot + No IMEI / Wifi etc look : http://www.youtube.com/watch?v=tcrxZh_li...
6条评论
Glad we sorted it out without selling.... Nice one!
由 pollytintop 完成的
thanks for adding this info victor, it should be really helpful to someone!
由 pollytintop 完成的
thanx for the information i will try this thanx
由 SIMRAN 完成的
I have the exact same problem and can't fix it
由 Tom 完成的
Hi Victor also I am having this issue regarding the original battery .. did it ever show any signs of dieing out ? was the only way to remove the battery and replace new .. can you also tell me how do you think you left out the battery from the board before you placed the new/old battery back and everything worked? cheers
also do you recall your orginal battery part number vs your replace part number too please thanks alot
由 mick 完成的
显示更多的1条评论
