跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 shutting down randomly
I have a customer that has a iPhone 7 it keeps shutting off randomly even after battery replacement and software up data and DFU restore.
any other reasons this could be doing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
A lot of things can cause the phone to randomly shutdown. Did the customer share any history of the device, such as previous repairs, drops or other impacts, cheap chargers etc.? I know you said randomly but have you or the customer been able to see any form of pattern, such as usage, apps, conditions or modules being used (camera etc.)? If it is truly random, it will be hard to figure out.
Start with a really thorough inspection with a microscope. Look for anything out of place or normal, such as traces of water (even if the LDI’s are good), dislodged or partially dislodged components. I like to nudge the coils as sometimes they are barely hanging on and can cause intermittent problems. Just don’t nudge too hard :>).
这个答案有帮助吗?
得分 2
添加一条评论
First check the BSI ways or the center pin of the battery connected properly or not.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 905
