跳转到主内容
加入维修社区 - 创建账户
于 1994 年 12 月 3 日在日本发布,9 月 9 日在北美发布。型号包括 SCPH-100x、SCPH-3000、SCPH-3500、SCPH-500x、SCPH-550x、SCPH-700x、SCPH-750x 和 SCPH-900x。
What is the parallel I/O port used for?
I found a parallel I/O port at the rear of the PSone. What is it used for?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
6个答案
已选择的解决方案
"The removal of the parallel port was probably partly because no official add-on had ever been released for it, and partly because it was being used to connect cheat cartridges that could be used to defeat the regional lockouts and copy protection." from here I guess at the time Sony had some ides of using it for expansion and different controllers but later abandoned the plan. Hope this helps...
这个答案有帮助吗?
得分 5
1条评论:
I bought a gameshark/chip that plugged into slot and allowed me to play "burned CD" games, that I copied from blockbuster. This slot chip was easier than soldering a chip inside...plus gameshark cheat codes
完成的
添加一条评论
It was used to end vietnam
这个答案有帮助吗?
得分 3
1条评论:
Thanks you sir
完成的
添加一条评论
This port is used for connecting 2 playstations together. Used for playing games with other people using 2 tvs
I like jetmoto.
这个答案有帮助吗?
得分 2
1条评论:
No, that's the Serial Port you're talking about. Serial Port was available on every PS1-model, but Paraller Port (the big one) was removed from SCPH-9xxx series onwards.
完成的
添加一条评论
it can be used for a super gameboy booster which will let you play first generation gameboy games on playstation (NO SOUND TO IT) but you can litten to music cds while you play
这个答案有帮助吗?
得分 1
添加一条评论
It was also used for an add-on that allows the PS1 to play movies
这个答案有帮助吗?
得分 1
添加一条评论
Used for Action Replays, GameSharks, VCD adapters, the long-awaited PSIO adapter, and Game Boy (some idiot's probably gonna "correct" me by saying "its not game boy its game boi") Adapters. The only time that is was actually used by Sony was for the debug units' PC parallel port (Or SCSI) adapter.
这个答案有帮助吗?
得分 1
6条评论:
No my good man, it's game boiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
完成的
Let me correct you, this is a common misconception. It's actually called Game Boi, noy Game Boy.
完成的
yeah even by nintendo itself! on every original gameboy/color/advance is gameboy written!! (disclaimer: the first sentence is ironical)
完成的
@Sora, it's not. Lol. It's 'Game Boy'.
完成的
Why am I here 10 years later?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Honam1021 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 52
过去 30 天: 170
总计 54,535
