跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why won't the screen click into place?
I tried to open the device and take the screen off (it was my sister’s phone), she wanted me to stop and I barely had it open, so I went to click the screen back into place, but it won’t click into place. Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
How can I ask a question like this on iOS?
完成的
添加一条评论
3个答案
已选择的解决方案
What happened was I partially separated the bezel from the glass, so I had to replace the entire screen.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hello,
Are the corners of the device in the same condition as when the device was purchased?
If there are any bends in the outer casing the phone screen wont go down properly. To fix this you need to take the display off and unbend those corners. Make sure when you’re putting the display back in you push the screen in from the top first as it has a little lip to fit flush with the casing, then push down on the sides/bottom.
这个答案有帮助吗?
得分 1
2条评论:
Thanks, but that's not what the problem was.
完成的
Could you add pictures if you haven't already fixed it?
完成的
添加一条评论
Hello,
As you said the corners of the device are fine, then you may simply have to lift up the screen, and reinstall it, putting it in place from the top, down the sides, and then by the home button. It is practically impossible to put a screen back down if it is partially up.
If the glass is cracked, then I recommend replacing the screen.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aiden M 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 341
