跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Mixers.
Mixer won't turn on
Accidentally caught rubber spatula in mixer blades while making a batter, a spark burst from the seam where I assume the motor is on the top of the machine, and now it won’t turn on. It’s a Sunbeam Electronic Mixmaster, Model No. 01401, Service No. 1-40CD, Listed 423A. Pretty sure I killed the motor, but can it be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Sadly and unfortunately there’s not many parts, what I seen on EBay etc, are the motor base for 50$. :/ which is the Mixer without the Accessories, bowls, blades etc.
完成的
添加一条评论
1个答案
When an electric motor gets locked, it gets hot really fast. I’d guess if this goes on for more than about 5 seconds some electrical part will burn, melt, break. It probably can be fixed, but somebody has to open it up and figure out what got damaged. Replacement parts are usually available on line.
I looked up your Sunbeam model number on line and there are all sorts of sites who will sell you parts or talk you through a diagnosis. Try this yourself.
这个答案有帮助吗?
得分 0
1条评论:
The brushes of the motor are probably dead, or the copper coil wraps.
@cgulyash can you link those sites for the Author?
完成的
添加一条评论
添加你的答案
Carol Ashey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 572
