跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone won't charge but logic board gets warm
Okay so I was recently changing an iPhone 7 screen and I unplugged the battery from the logic board. I know it’s stupid but I didn’t realise the screen was still turned on. Now when I charge the device it no longer turns on or shows any response. However, after a while the logic board gets warm. I’m not an expert so I need a little help. It’s definitely not the screen because it was working before. The backlight is fine and the charger is working. Any ideas as to what the problem might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Did you try a soft reset? Just asking,trying to see what troubleshooting you did.
这个答案有帮助吗?
得分 1
3条评论:
I held down the power and volume down buttons for a while. Didn't work. The battery had issues before I even worked on the phone as well, it hadn't been turned on since December.
完成的
Did you try unplugging the battery and plugging it back in because it sounds like you did the screen replacement with the battery plugged in the whole time.
For doing any screen repair it's good practice to unplug the battery first if possible or soon as possible.
完成的
It's quite confusing but I actually successfully completed the screen replacement to test the actual screen. Then I did it all again to fit in the home button, that time it wouldn't charge again.
完成的
添加一条评论
How do you know all these things are working if you are getting no response from the phone? do you have a power monitor you can hook it up to and see if you are pulling anything at all??
这个答案有帮助吗?
得分 0
2条评论:
I don't have a power monitor, but I know these things are working because they worked literally seconds before. I checked the backlight with a flashlight and the charger works with my other phones. I tried the old screen (which was cracked but working) and still no response.
完成的
Do you have a multimeter to test circuitry? You may have shorted something when you disconnected the battery. There is definitely some testing that will need to be done before you can find a solution or verify parts work.
完成的
添加一条评论
添加你的答案
Tahiyan Choudhury 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 63
