跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
90 个问题 查看全部
问题已关闭
My PSPgo don't show a menu "Home"?
I changed the gameboot to another one, and it worked, but after I reset the psp it didn't show anything, it just show the wallpaper without anything like (menu, clock, date,..).
I wish someone tell me how to solve this problem.
Thanks.
About my PSPgo :
- Version : 6.35 , and it's 6.35 PRO-B
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Please someone help me.. please..
完成的
添加一条评论
4个答案
最有帮助的答案
It's running custom firmware, so you're in luck. I'm not too familiar with the slims, but you need to download the stock 6.35 update, and boot your PSP into recovery mode. Do this by turning it off, and turning it back on while holding down the right bumper. A menu should come up on the screen. Select "Toggle USB" and connect it to your computer. Now, rename the 6.35 Update that you downloaded "EBOOT.PBP" (if it isn't already named that), and copy it to "/PSP/GAME/RECOVERY/" directory on your PSP's memory stick. Now on the recovery menu, select "Run program at /PSP/GAME/RECOVERY/EBOOT.PBP" Your PSP should procede to reinstall stock 6.35 Firmware. Once the firmware installs, reboot the PSP. It should now be working on stock 6.35 firmware. You can now go back, and reinstall your custom firmware.
这个答案有帮助吗?
得分 3
2条评论:
No!! I can't go to Reecovery Mode by using 6.35 PRO-B, and I have PSPgo.
完成的
can you access the VSH menu? Press "Select" while at the XMB screen.
完成的
添加一条评论
NO! it's psp go ! so I can't go to Recovery mode by using 6.35 pro-b.
这个答案有帮助吗?
得分 0
添加一条评论
Well 6.35 Pro is a LCFW so a Hard reset will return your device back to OFW.
This is done by holding the power button for 10 secs or more. Device will power off. Failing that disconnect the battery [if your careful the warrenty sticker will still be valid]
If you didnt try to perma patch then you should then boot back into the enter settings screen.
If you still have no XMB and you left USB mode to auto connect then see if the device is still allowing for usb mode.
If you have access to a docking station then i have known that to "kick" the device back into being sensible
这个答案有帮助吗?
得分 0
添加一条评论
smash your psp
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 3,846
