Can I use a surface pro 4 screen replacement on my surface pro 3
My surface pro 3 screen is broken and I was wondering if I could replace the screen with a surface pro 4 screen? are the Pro’s and Con’s on this?
thank you
As far as I know it is not compatible as they are using different cables for the LCD and touch screen, one uses a touch screen daughter board behind the screen and the other does not.
I’ve replaced a few screens on both models and I would not risk it to try a different model screen on either.
这个答案有帮助吗?
Thank you, that makes sense.
Nope. I tried that. The screen size is the same. It fits, but the resolution and flex cables which go to the board are completely different.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 37
总计 830
