跳转到主内容
The Acer Chromebook 14 is a Chromebook with a 14" display, released from Acer in 2016. Model Number: CB3-431.
12 个问题 查看全部
power cord small pin loose
power cord small pin loose; replacement of power cord did not correct
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
@revmah provide the image of the pin
完成的
I have the same problem. How do I open the Chromebook? Thank you.
完成的
Same here. I had it for less than a year and a new power cord doesn't fix it. I had to hold it in with my knees pushing it in all I can type. I say this is a waste of money because it was cheaply made and cannot be fixed. Will never buy again.
完成的
Nice to know I’m not alone. Still no fix.
完成的
For this model, you can buy and replace the charge port easily (assuming availability) since it's a cable based jack, not a soldered on jack.
EDIT: Label for the charge port has P4GCR on it. Typing P4GCR cable into a search engine will yield results.
完成的
添加一条评论
3个答案
已选择的解决方案
if you mean the pin in the socket of the actual laptop then a new charger wont fix it, it will probably need a new charge port
这个答案有帮助吗?
得分 2
3条评论:
can a new charge port be installed by a layperson?
完成的
should be easy enough i dont know if theres a guide on here for it
完成的
Did this work?
完成的
添加一条评论
Take off the back cover by removing the small Philips screws and gently pry off the back. Check the power connector, there are plastic tabs that hold it tight to the side of the case. They break easy so you need to tape it down with electrical tape or glue it in place.
这个答案有帮助吗?
得分 2
添加一条评论
The port is going to be loose, if you look at the port internally. It is not actually attached to anything inside and is held in by a clip, this is what causes it to be wobbly
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
RevMAH 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 1,646
