跳转到主内容
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
8 个问题 查看全部
Have a white screen on power up
Moniter was on and all of a sudden went white. Now it is always white no matter what I do. Is it a motherboard issue or something else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
White screens are usually indicative of a bad hard drive or corrupted boot system.
这个答案有帮助吗?
得分 2
添加一条评论
mrbruce300  on your monitor this just means that only your backlight is on. You will have to check the video source and see if it is connected etc. If the monitor does not show a menu etc. on startup when disconnected from a video source you most likely have a bad main board.
These monitor had issues with bad caps, so you will have to take a look at the boards and check for an obvious damage. Post some images of the boards with your question so that we can see what you see. 在已经存在的问题里加入图片
Here are the disassembly instructions disassembly.pdf
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mrbruce300 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 82
