跳转到主内容
Model A1285 / 8 or 16 GB capacity
206 个问题 查看全部
Is reset normal with bad battery?
Works fine when plugged into power. Disconnect from power, and it shuts off. Reapply power, and it comes to the language selection screen. Is this reset normal with a bad battery, or does it indicate a different problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
mgb2, Yes it would be normal. Happens to my iPods with a dead battery all the time. Remember that when you unplug it, it has absolutely no power and can not retain any information. When you plug it in it starts as if its never been setup before. Of course that does not preclude any other damage, but I start with the battery for sure. Good Luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mgb2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 743
