跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 个问题 查看全部
bottom case reassembly screw order
To ensure that the bottom case is solidly assembled, is there a strict order to put the screws back when doing a bottom case reassembly on the Macbook Air 13" (2010)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
with the help of macrumors.com community, I've got the special order of putting the screws back for the MBA 2010. I have no idea how to attach an image to this comment like WiseGeek did, so here's the link to the image: http://is.gd/A30Ga3
完成的
Then why is there 3 long screws in the replacement pack if it only calls for 2?
完成的
添加一条评论
2个答案
已选择的解决方案
Here is an illustration:
这个答案有帮助吗?
得分 2
4条评论:
wow, that's great! but that's the guide for the original 2008/2009 MBA, I wonder if the same order applies to the new one (2010), which has a slightly modified case design.
完成的
+ that's what I'm talking about. Could you give a link to that image?
完成的
well, since we're talking about the 2010 MacBook Air 13" model, the bottom screw assembly is on page 120 of the Technician guide. Here's the link: http://is.gd/A30Ga3
完成的
Of course, you are right. Just like you said it is page 120. Anyway, here is the complete service manual for the MacBook Air 13" late 2010.
完成的
添加一条评论
最有帮助的答案
I put the screws in loosely and then tighten them like lug nuts on a tire.
这个答案有帮助吗?
得分 2
3条评论:
and does the bottom case sit solidly by doing so? no creaking noises from the case?
完成的
They have for me.
完成的
thanks. that's why I'm asking. maybe there is a special order to put the screws in so the bottom case would be properly aligned.
完成的
添加一条评论
添加你的答案
sergesavranchuk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,974
