跳转到主内容
First generation, based on the Ford C1 global platform.
23 个问题 查看全部
Bell housing bolt patterns at Vs mt
My 2006 Mazda 3 threw a rod. I'm looking for a replacement engine. What I need to know is if I can get an at engine for my manual car and just swap the flex plate for the flywheel. I've heard rumors that the bell housings are different. Any help would be greatly appreciated. Thanks.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Ok awesome thank you so much.
添加一条评论
1个答案
已选择的解决方案
As long as you get the same motor then it should just bolt up , doesn’t matter if it was auto or standard . you will have to change the flywheel ,just use your old one . you will also need the spacer plate for the starter from your old engine (depending on the year) as well
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
Luke Jensen 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 34
