跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
iMac does not start; boot chimes in a loop
I have a imac that does not boot; the startup chime comes up every 2 or 3 seconds and the display is black. I don’t have the boot disk.
Pls recommend fixes that I can try myself. I unplugged the cable and attached it. there are no other devices connected to it now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Zap the PRAM; hold down CMD+OPT+P+R while turning on the machine, keep it held down until you hear the third startup chime, then release and see if it boots.
Hold down the OPTION key at startup and see if the boot volume selector comes up. If it does, you may have a hard drive or OS problem.
这个答案有帮助吗?
得分 1
2条评论:
Thanks. I don't have an apple keyboard . I use a PC wireless USB keyboard. What would be the equivalent keys? thanks again for taking time to reply.
完成的
You’ll need a USB wired keyboard & mouse with this older system until you get it working. Do you have the grey CD or DVD that came with the system?
完成的
添加一条评论
添加你的答案
Srinivasen Samy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 123
