跳转到主内容
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
My flash getting hot,when ı plug into my laptop.
I have SanDisk ixpand 32 GB (2 years old) and a brand new SanDisk Ultra Fit 3.0 32 GB USB thumb flash drives.
My problem is, both flash drives are always getting hot when I plug them in and do any file transfer.
  • What can I do to prevent them from overheating ?
  • Is this harmful to them ?
Thanks,
Regards.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Heavy file transfers will cause the drive to get warm. This is normal.
完成的
SanDisk flash drives are widely copied. Only the fakes get really hot! A genuine drive just gets warm to the touch, after read/writing.
完成的
添加一条评论
5个答案
已选择的解决方案
It is normal for a flash drive to get warm duing use. (my sandisk cruizer blade gets quite warm when moving files from it)
这个答案有帮助吗?
得分 5
3条评论:
maybe his computer is very hot itself, you know
完成的
No I had Omen and enough cool .
完成的
SanDisk flash drives are widely copied. Packaging and the products appear 100% genuine, but only the fakes get REALLY hot. It's really difficult finding an on-line store that sells the real item!
完成的
添加一条评论
Run Task Manager to see if there is a lot of drive activity with regard to the USB drives.  (A lot of continual drive activity could cause heat.)  If there isn’t, then the USB port is likely putting out too much power.  I don’t know how that could happen, unless there is a chip in the computer which is bad and which controls power output.
If there is more than one USB port, does the problem happen when you plug the flash drives into a different USB port?
这个答案有帮助吗?
得分 3
1条评论:
I will try it but i connect my ixpant to my iphone and same happens .
Thanks,
Best Regards.
完成的
添加一条评论
Good flash drives will throttle their transfer speeds down to accomodate for heat output from the flash drive itself. Nothing to worry about. I have plenty of flash drives that do this due to heavy file transfers and they are still working till this day so it’s normal.
这个答案有帮助吗?
得分 1
添加一条评论
Poor design factor. Doesn't matter what computer I use the Sandisk Ultra Fit in, it always ejects *HOT*!
这个答案有帮助吗?
得分 0
添加一条评论
Ultra Fit 3.1. Just bought new. Original product, not fake, as proven by the PrivateAccess software. Just plugged. No transfer. After about 5 minutes, so hot. Not warm - hot.
For anyone who says only fakes get hot. Please only share information you can back up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 20,761
