How can I replace a micro usb port from a Steelseries Stratus XL
I bought a used Steelseries stratus XL controller from Ebay which I was using wired since my PC doesn't have Bluetooth and somehow while I unplugged the controller , a micro USB pin came off. Since it was one which was at the edge, I knew for a fact that it was one supplying it with power. So I tried to open it so as to be able to plug in the microusb cable and the battery at the same time, but for some reason it doesn't output any signal if batteries are inserted.
I do have an old phone and a broken controller with both having a perfectly fine microusb port which I could remove it from, I also have a soldering iron and solder but no helping hands. I am just asking how can I remove the microusb port and apply it in the controller. Also It is not the steelseries nimbus but the stratus XL for android and PC it's just there is no stratus XL on the device list and the nimbus has to be the closest thing.
