跳转到主内容
The Coolpix P530 is a 16.1 megapixel digital camera with an impressive 42x optical zoom. This model was released by Nikon in February of 2014. It also goes by the manufacturer specific model name Nikon 26464 .
20 个问题 查看全部
Camera Won't Turn on After Many Hours of Charging
Hey all,
I got this camera as a gift a few years ago, but never had much use for it, so I kept it stored safely in its case. I recently picked it up again, and have had it charging while plugged into my computer for about 12 hours now, but it still won't turn on. There's been no damage to it whatsoever. It does flash green and beep when plugged in, so one would assume it is charging...
Can anyone help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi Bev Cummings , had you tried taking the battery out from the device and use an external charger to charge the battery?
do you have a multimeter?
after some time of charge, use a multimeter to measure the battery, to ensure it is holding on the charge, which i suppose is around 3.7V
完成的
Unfortunately I don't have a charger that will fit the battery, or a multimeter. Should I just assume I need a new battery?
完成的
添加一条评论
2个答案
已选择的解决方案
Bev Cummings  since you have not used it in a few years, it is safe to assume that your battery has discharged below a threshold where it will charge again. Repalce the battery and then re-evaluate.
这个答案有帮助吗?
得分 3
添加一条评论
Hi beV I have This problem to? Did you manage to resolve the problem?
thanks Kelly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bev Cummings 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,758
