跳转到主内容
laptop boots directly to BIOS. Wont recognize Hard drive.
laptop boots directly to BIOS. Wont recognize Hard drive. When I try to boot from USB it boots back in to the BIOS... I have tried re-flashing the BIOS and that did a whole lot of nothing... Any help greatly appreciated. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey Ethan
Start by checking on the BIOS boot sequence, I believe Asus uses UEFI BIOS systems, so look for a HDD logo. Make sure that is the first bootable device in the systems list. This sometimes is the source of the problem when windows does updates. The Windows Updater can mess with the boot sequence because it needs to restart to finish completing.
If the boot sequence looks ok, then check to see if your drive is even recognizable. If you need to boot from the USB device, make sure the BIOS has USB booting enabled. You should also check to see if the BIOS uses UEFI booting or EFI (Legacy). If it is using the UEFI you will need to either build the USB device to a UEFI configuration, or enable Legacy mode on the BIOS system itself.
If the problem still persist where you cannot boot from either device (HDD and or the USB drive) then you may need to try a Genuine Windows Install Disk. You can also take a HDD with a installed version of Windows and connect it to the system board of your Asus to test if it boots. If it does check the formatting for your HDD you had in the laptop. If it doesn’t try to remove the CMOS battery for about 2 minutes and re-connect it to reset the boards controllers.
Good Luck!
这个答案有帮助吗?
得分 0
2条评论:
I have tried all the above. And I couldnt find the CMOS battery
完成的
Your CMOS battery should be under a compartment door on the rear of the laptop. Its most likely next to the RAM or Wi-Fi antenna.
完成的
添加一条评论
添加你的答案
Ethan Leroux 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
