I spilled a sip of liquid (flat white) on my MacBook Pro TB 2017?
I accidently spill some liquid (flat white) on my Macbook pro 2017 Touchbar, luckily I had a keyboard cover which protected the keyboard, but some fell on the speakers grill (on the right side) I cleaned it right away with my fingers and napkins then put a napkin on the speakers grills, closed the lid and put the macbook upside down so it can be drained somehow with gravity, I think the napkin was very very slightly wet that it can barely be noticed after I removed it, then put a new napkin again and left it upside down till I reached home 2-3 hours later, I removed the napkin it was dry and I used a vaccum cleaner 5-10 times on the speakers and the keyboard close to it ,The macbook is working normaly till now and the speakers also are working as usual I guess, I’m really worried that there might be some damage that I can encounter later, my question is , How long should I wait to be relieved that nothing would happen ?
And also if there is something else I should do ?
Sorry for the long post.
Thank you in advance.
3条评论
To be clear this is white ceiling/wall paint.
How much did you spill? Is this a thick paint or very runny? As it turns out the speakers can be replaced and you can gain access to the inside surface of the grill
由 Dan 完成的
no no flat white is an espresso drink, it’s like a cappuccino, I’m not sure exactly how much but I hit the cup and it moved a bit it didn’t fall or anything I think I spilled about 3 cm3 or something, I tried the speakers volume it seems normal to me, everything seems so normal but I’m panicking that I might encounter some damage later, I tried vaccum cleaning it a few times and everything is fine till now
由 Peter Labib 完成的
So you use a torch Vs a flashlight ;-}
由 Dan 完成的
