跳转到主内容
Repair information for the Garmin Vivoactive HR smartwatch. Released in February of 2016. Model number: 010-01605-03.
21 个问题 查看全部
Won't respond or charge
My watch was on low. attery amdnstopped responding, time is stuck at 5:09, non of the buttons work, I cant turn it off. The screen lights up when I press button but won't turn off. When plus into charger nothing happens. Please help:)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Let Try this
push the two buttons at the same time about 15 second.
The screen will light up again & will back to normal work.
Good luck.
Adisorn T
完成的
添加一条评论
2个答案
Try removing the battery for 30 sec and replacing the battery. This should reset your watch.
这个答案有帮助吗?
得分 0
添加一条评论
Plug into the charging cable and power source, then hold power button for 5 seconds. This will enter forced test mode. Scroll through the screens and check your device statistics.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gina marie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 6,509
