跳转到主内容
Bluetooth on-ear headphones with 40 mm drivers and a 610 mAh battery. Released in 2014.
Sometimes won't turn on even when battery is not empty
Hello everyone,
So at first, I thought the issue was the battery, I assumed it was getting emptied faster than usual due to its age.
So I did a simple test, I charged fully and didn't use it for couple of weeks to see if it would discharge anyway but it didn't.
Later I realized that if I leave it on the 'waiting for connecting stage' and I let it auto-turn off (I guess this feature is there for battery saving when going idle) It won't turn on again until I plug it in the charger, 3 seconds of charge is enough to revive.
Could it be something else failing beside the battery? I also have checked the voltage of my battery and it was giving 4.1V (3.8V battery)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
I had same problem, in my case it was becausecable connecting battery and speaker with board connected togedher plus from battery with plus on speaker
这个答案有帮助吗?
得分 0
添加一条评论
Well i think you will need to get new ones
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roje Ha 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 262
