跳转到主内容
The Kenmore Direct Drive is a washing machine by Kenmore.
58 个问题 查看全部
Why is my washer taking more than 2 hours to cycle
My Kenmore top load washer seems to do all the cycle steps, but takes more than 2 hours to do so. I had a technician come. No fault on the diagnostic test. He ran the automatic mode and that went fine. Then he did the calibration and found nothing wrong with the machine. But still no change after his visit.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I’d clean the filters. Then watch to see if it is running to long on a particular cycle. Make sure the water flow is strong when starting up (if not, it may be have a clogged screen in the water inlets.
It could also be a failing timer.
这个答案有帮助吗?
得分 1
2条评论:
Thanks sir for your response. Could you help me locate these filters? And if it is a timer problem, where can I locate it as well.
完成的
not without the exact model number.
完成的
添加一条评论
添加你的答案
DENIS BRASSARD 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,309
