跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Charging port replacement doesn't work
I have replaced the charging port on my iPhone 6 three times with new units. Each time the phone has little or no reception and cannot place or receive calls. I put the original port back in and each time everything works again. I even requested a port from one place that was compatible with Verizon CDMA and had the same results. I don't know how much longer I can get my phone to charge before the port craps out completely. Does anyone know why none of the replacement ports will work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
1.) Why are you changing a working charge port?
2.) Are you fully installing these ports or just overlaying them to test?
这个答案有帮助吗?
得分 2
7条评论:
I have to fight with it to get it to charge. The original port is very loose.
I did a complete install on all of them.
完成的
Ok, sounds reasonable. eBay and Amazon are the absolute worst place to get parts. Buy one from iFixit since they host this forum that offers free advice, and forum hosting is not free. When you get the new port, compare it to the old port under magnification--do you see missing small components, missing silicone "hot glue" protectant? The crappier parts are usually obvious compared to the original. Make sure that you are connecting your antenna to the board that some on the new charge port. Post pictures on here of your work if you're still having trouble.
完成的
I copied this from my comment on the answer above;
Well, I bought a new port from iFixit and put it in. The result....even worse than the Ebay and Amazon ports. I cannot send or receive calls or texts and I have no sound. I put the original port back in and everything works again. Just to double check I put the iFixit port back in and nothing works again. Doesn't anyone sell the Apple parts that actually work or are those for Apple repair centers only?
完成的
No one sells Apple OEM parts, and "Apple repair centers" don't exist--Apple does not change charge ports at any price. I understand that you bought an iFixit port--great, return it and try another one AFTER you check under magnification for how close is the iFixit part to the original. iFixit is not immune from selling bad parts just like anyone else, HOWEVER they put a lot of resources into customer service. I've brought systematic parts problems to their attention on more than one occasion and I know for sure that they pulled the remaining stock and made sure the next one they sent me didn't have the problem I mentioned.
完成的
I already e-mailed them to return it but I still have not received a response.
完成的
显示更多的2条评论
添加一条评论
Have you tried ordering a port from iFixit? Were the others ordered from eBay or Amazon? If your original works and the replacements dont, then there's a good chance you just received duds. The places I order from are original Apple parts (you can see the Apple logo on them) and I rarely have an issue.
这个答案有帮助吗?
得分 1
6条评论:
I bought 2 from 2 different dealers on Amazon and 1 from Ebay that was supposed to be for Verizon CDMA. I didn't notice if they had the Apple Logo.
完成的
I'd buy from iFixit just to quadruple check. I havent purchased replacement parts from Amazon or eBay for years because of getting consistent bad parts from multiple suppliers.
完成的
完成的
There are some other suppliers that sell original parts that I purchase from. Injured Gadgets and Mobile Sentrix both offer original charging ports. Unless their suppliers have changed, you can see the apple logos marked out on them.
完成的
Brian, All of the ports on those two sites now say "Aftermarket Quality".
完成的
显示更多的1条评论
添加一条评论
there is another part in the phone that is used for a cellular antenna, that could need to be replaced, that and i would also try DFU restore/update
这个答案有帮助吗?
得分 1
2条评论:
I tried the restore and it didn't help.
If another part was bad then the original part wouldn't work either, would it?
完成的
if its not the port then the original port is probably still good. but i still wont get your hopes up, it could be your audio ic chip which you can fix if you have micro soldering skills, but if not, I know there are a lot of ebey people that offer iC repairs
完成的
添加一条评论
添加你的答案
Curt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 410
