Please help me locate the temperature sensor on this MacBook
Hello guys, can anyone help me locate the temperature sensor on this macbook? The issue I'm currently facing is the fans go high each time I turn on the laptop and it's very very slow, the kernel task is eating whole CPU.
I've temporary replaced the screen to confirm my thoughts and the issue was gone. So, it must be sitting somewhere on the LCD panel, anyone knows where?
My guess it's somewhere on the LCD plate since I disconnected facetime and LED light flex cables and didn't reproduce this issue on the new screen.
Here's what hardware test saying: https://prnt.sc/k9i9n4
Update (07/23/2018)
So, basically it should be located somewhere on this LCD plate:
11条评论
It would likely be under one of the cans, or the LCD panel it’s self.
由 Dan 完成的
That's right, under the cans. LCD panel doesn't have it, I tested this by deattaching the LED lights flex cable as well as the Facetime.
由 Vadim 完成的
Did you see the chip I pointed out? Can you read the markings?
由 Dan 完成的
Thanks for getting back to me, Dan. Yes, I see it. Here's a better picture which was done by ifixit teardown: https://d3nevzfk7ii3be.cloudfront.net/ig...
So, is there any way to test it? I'm sure it's not somewhere on the LCD itself, only this board seems to be keeping it. I'll try to make a better quality picture of the item marked today to see the texting it has on.
由 Vadim 完成的
ok, updated photos. Now you can read what's printed over there.
由 Vadim 完成的
显示更多的6条评论
