跳转到主内容
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
46 个问题 查看全部
split screen, one side normal other side flipped like a mirror image?
Not able to find flip screen in my menu. Also my problem is different. The Split screen on the left side is normal but cut in half, the right side flipped like a mirror image. If there's lettering on the screen it's like your looking at it through a mirror?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@tgonz
post an image of what your screen is showing so we can see what yuo see. Use this guide 在已经存在的问题里加入图片 for that. It could be an issue with the T-con board or the panel. Verify that your TV is a Samsung LA40R81BD
You could rule out the T-con board by unplugging the individual ribbon cable for the side that does not show properly and see if nd what that changes. Due good side first, then the one that dispalys mirrored. Let us know what you find.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Teresa Gonzales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 724
