跳转到主内容
修复你的物品
维修的权力
商店
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2515 个问题 查看全部
Incorrect password and unable to join
i got 2 iphone 6s that i bought from a person and he said to me they work fine but they don't connect to wifi nettworks.
So i got them i have DFU restored both of them - SAME PROBLEM
I have changed their wifi anntenas - SAME PROBLEM
I have cleaned their motherboard with alcool - SAME PROBLEM
so i decided to ask you guys if you have any knowlege about this problem i know it's motherboard fault but i'm not good and finding problem by myself.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
最有帮助的答案
The phones are iCloud locked. You’ll need to ask the seller to unlock them if he can’t then return them and get your money back as they are likely stolen!
And No there is no way to unlock them. Think of it this way… You have an egg in your hand without cracking (opening) the shell open can you get whats inside out? Nope!
Same here you can’t get in without breaking the iPhone.
这个答案有帮助吗?
得分 1
评论:
They don't have icloud account open i mentioned that i have restored them with itunes in DFU mode they started like every unlocked iphone
Anyway thanks for your contribution
完成的
DFU mode does not undo the iCloud lock. All you've done is refreshed the phones firmware if needed
完成的
So I assume these phones have passed the activation setup page.
Is the Wi-Fi able to turn on? Or is it stuck greyed out off?
完成的
@danj If you hard reset the iPhone and it has iCloud and find my iPhone on you just can't pass the activation setup page. They passed it as they don't have iCloud lock.
@benjamen50 The WiFi turns on and its range is perfect but in every router that i want to connect even with password or no password the popup just shows up and says "Incorrect password" or "Unable to join network"
完成的
添加一条评论
Help! I have the same issue and my iPhone is brand new from o2 the day they were launched so I know it’s not a knock off!
这个答案有帮助吗?
得分 0
评论:
Bring your phone to an Apple Store with your sales receipt.
It turns out your phones ID may have been stolen by someone! Basically, they used a utility Apple made available a few years ago to find unused Phone ID's to use on their phone. So when you tried to setup via the activation setup page it won't work!
完成的
how to get back phones id if u don't have an apple store nearby
完成的
添加一条评论
添加你的答案
Adrian Zymeri 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 3,700
