跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1645 个问题 查看全部
Ice maker (Whirlpool wrs325fdam02) not working right.
The problem: ice is no longer being made. Water dispenses fine. Ice control arm is in the lower (on) position.
Attempted fixes: replaced water filter, replaced ice maker (entire unit) and replaced the water control valve.
Ice maker is cold enough. Water pressure is high enough. What am I missing? Water is not being called for in the ice maker? New control valve installed 2 days ago at water intake.
Is there anyone that can direct me to something I might have missed here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You’ve replaced the major issues. Now for minor ones to look at.
Cause 1
Door Switch
The door switch turns off the ice and water dispenser when the refrigerator door is open. If the door switch fails, the dispenser will not turn on. To determine if the door switch is defective, use a multimeter to test it for continuity. If the door switch does not have continuity when activated, replace it.
Cause 2
Icemaker Mold Thermostat
The icemaker mold thermostat monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature, the icemaker ejects the ice cubes and refills the ice mold with water. If the mold thermostat is defective, the ice maker will stop making ice. To determine if the thermostat is defective, use a multimeter to test it for continuity. If the mold thermostat does not have continuity, replace it. (Note: If the ice maker is not cold enough, the mold thermostat contacts will open. If the thermostat contacts are open, the ice maker will not make ice. The ice maker temperature must generally be lower than 20 degrees Fahrenheit for the thermostat contacts to close.)
这个答案有帮助吗?
得分 2
2条评论:
Ice maker thermostat is in the icemaker unit isn't it? I replaced the entire unit. Or is it separate and located elsewhere?
完成的
Door switch lights up the freezer section. Is there another door switch?
完成的
添加一条评论
添加你的答案
Brother Rain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 3,048
