跳转到主内容
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
158 个问题 查看全部
Will an Xbox One X still function with a removed disk drive?
As the subject indicates, if I do not use any optical based games, will the Xbox still run with one not installed? Or will the PCB from the drive still at least need be connected? I ask because I will be installing my second Xbox into a custom case. Which I understand is warranty voiding, but it was bought used.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes it will work fine but keep in mind that at some point they might start doing what Sony is now doing…requiring a hardware check with each update. If the disc drive isn’t working on a PS4 then it won’t update.
这个答案有帮助吗?
得分 2
2条评论:
you can attach the daughter board from the drive as a workaround that!
完成的
Is this still the case now or did they do what Sony did?
完成的
添加一条评论
添加你的答案
Marlon Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 35
总计 1,806
