跳转到主内容
The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
Why is my espresso weak AFTER thorough descaling?
My actual model is DeLonghi Bar 41 pump driven espresso/capuccino machine, but could not find this model as a menu option. I recently did a thorough descaling and cleaned the boiler outlet as described in the manual. For descaling, I ran about a half cup of solution through the macjine, paused about 15 min, then repeated about 5 times before running the remaining solution through the machine. After doing this, the espresso is coming out very quickly, tastes weak, and has little or no crema. I'm using the same coffee, same amount, tamping exactly the same way. Is it possible my descaling damaged the machine? Any ideas about what to do next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I think it might have something to do with your spring tension which might be less causing water to come out with lesser pressure. Open up the diffuser and try and stretch the spring a little bit and reassemble. That should help with the water flow.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Asta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 518
