跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
home button reassembly questions
Hi all , im having a bit of trouble with getting the home button assembly back on a new screen of this ipad mini 4 i have here .
I fitted a new gasket with the home button ok but the bracket i cant seem to align it so the home button clicks , the home button does still click out of the frame , but im not sure if it's because the tape i stuck the bracket back on with is not strong enough as it does flex a bit .
Also the plastic spacer ring , i assume this fits between the home button and the bracket but does it sit on top of the flex or under it ?
I have some of this tape https://www.amazon.co.uk/gp/product/B00B...
on the way ,hopefully it will be stronger than what i have here , i was thinking of also adding a few drops of hot melt glue for extra support , is that a good idea ? .
any advice appreciated ,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Perhaps the double sided tape is too thick and lifting the back bracket by a small enough fraction to cause issues. You could try to bend the bracket a bit so that it swoops down and forces contact with the actuator.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
markparnell1972 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 65
