跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
What should I do if my front camera is scratched
Basically there was glue on my phone and I was trying to scrap it off and it,as I was doing this the camera got scratched in the front camera.So now when I take pictures it’s foggy/blurry,what should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Replace the front camera assembly.
If you are talking about the glass on the screen either clean it or replace the screen.
这个答案有帮助吗?
得分 1
添加一条评论
Using a Cotton Bud - wipe Petroleum Jelly onto the camera lens then gently wipe clean with a Microfiber cloth.
The purest petroleum jelly, like Vaseline, works best.
The idea is that the jelly fills in the cracks and lessens the effect it has on light passing through the lens.
Alternatively - these can be replaced. Pop into your local repair branch - as prices can vary depending on model :).
https://www.pcheroes.co.nz/news/30/54/Sc...
这个答案有帮助吗?
得分 0
1条评论:
If I get my screen replaced because I have a cracked screen does it mess up my Face ID ?
完成的
添加一条评论
If the glass scratched, the best solution is to change the whole screen. It is not expensive and you can do it easily. On this way your front camera will take good pictures again. During the repair you can clean the camera and camera lens on the front glass inside and outside, and your pictures will be even better in the future.
Here you can find a guide: iPhone 6 LCD屏幕面板的更换
这个答案有帮助吗?
得分 0
2条评论:
Ok but how much do you think it will be?
完成的
On Ebay the iPhone 6 screen is under £20.
完成的
添加一条评论
添加你的答案
Bri Elle 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 77
总计 9,019
