跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
I was doing some work on my mbp, suddenly everything went blank (off)
Suddenly my mbp in mid of work goes off abruptly at once. It was not in charging, And now when am trying to turn it on it doesnt. Tried the SMC bypass, hard power cycle by putting power cable and removing while holding power button. Nothing is working, no light is flashing, no fan sound nothing! Complete Dead
one observation, I inserted my mbp charger to charge the macbook thinking my battery might be dead ... (even though am sure that it was close to 50% when it abruptly went off) .. What i Obeserve now is even after three or four hours (normal full charging time is 1.5- 2 hours) the charger is still orange/amberish and not turned green.. is it an indicator that logic board is dead? Is is the logic board that signals battery is full. Charger is moderately warm, like it should be after 2 hours and then is at normal temperature indicating the battery is charged fully (my guess) but still the amber light is on and not green.
Aprt from this nothing visible... This is my 2nd MBP in 4 years... I really am contemplating what am I doing wrong with these beasts or if these are not worth at fist place!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Disconnect everything from the logic board and try to start it with connected charger. If it is not start, disconnect the charger, and try to start with connected battery.
If the board still not start, most likely your board is faulty. If any of your other part faulty (like battery, keyboard, ssd etc, your board will start on this way.
这个答案有帮助吗?
得分 0
1条评论:
Another method to find if logic board is dead or not,..? I don't have accessory to open bmp
完成的
添加一条评论
Did you try any one of the following?
  • Holding boot up key combination to reset NVRAM
  • Replace Power Adaptor
  • Apple Hardware Test to diagnose any hardware issue
  • Booted up Mac in safe mode
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Avi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
