Dryer spins but no heat (Maytag MED9600SQ)
Maytag dryer seems to be operating fine other than it doesn't seem to be heating at all. The heater was replaced in '07. Manual just says to check house breaker, which I did, and then call an electrician.
Please give us the model number, I don’t know if it is a gas or electric.
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts
https://www.searspartsdirect.com/model-n...
How to do it:
https://www.searspartsdirect.com/repair-...
Cause 2
Replace the dryer heating element
The heating element generates the heat needed to dry garments. If the dryer is not heating, check the element for visible damage and replace the heating element if it's broken. Almost all electric heating elements require 240 volts to function correctly; if the heating element won't heat even though it's getting the 240-volt power, replace it even if it doesn't look broken.
How to Replace a Heating Element in an Electric Dryer
这个答案有帮助吗?
My apologies. I thought I put that it was an electric and I also thought that number was the model number. But the model number is: MED9600SQ
my problem was that centrifugal switch on motor was dirty cleaned it up a little lubricant and it works I replaced nothing...see youtube video...https://www.youtube.com/watch?v=6wnEEIAs...
I need to get the shield off to get the eliment and instructions
这个答案有帮助吗?
Gary Did you go to the guide link I gave that shows the shield being removed?
Is the exhaust hose blocked or clogged? I’ve had a dryer that wouldn’t dry because it couldn’t exhaust the air.
这个答案有帮助吗?
Hi, i need advise my dryer is not producing heat. Already checked and cleaned the exhaust, replaced heating element and all thermal fuses. Still no heat.
maytag 3000 series
model: YMEDE301YG0
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 160
总计 36,660
