跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2692 个问题 查看全部
iPhone 6s shows ,,Device unknown''
Hey guys,
i have an iPhone 6s, which shows ,,Device unknown'' after selecting language and country . I can not activate it.
If it powers on, it takes about 3 min, until the apple logo dissapears and until i can choose the language.
iTunes does not recognize the iPhone, no matter if i try to put it in recovery or DFU mode.
iTunes and the iPhone has the actual software. I also tried to change the battery, but it didn't help.
Thanks in advance for your help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
Hi. I am having exactly the same problem. My iPhone 6s is on 12.1, but will not connect to anything via USB and will not charge. I get the device unknown error too. There is no SIM in the phone and I’m using a proper nano when there is.
Could this be a sim reader problem?
I have changed the charge port, battery, screen, cameras, etc. to see if there is a short somewhere, else but no joy so far.
这个答案有帮助吗?
得分 0
添加一条评论
Fix my iphone Device unknown
这个答案有帮助吗?
得分 0
添加一条评论
I've seen this happen twice and in both cases it was caused by a SIM card that was damaged when it was being trimmed down from micro to nano size. You can test this by removing the SIM card and then trying to put it into recovery or DFU mode; if it works, you know the SIM card is a problem and you will need a new (undamaged) nano SIM card to fix it.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 5,209
