跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Call "Ended" Almost Instantly
Hello,
I have a iPhone 7 where as soon as you make a call, it says 'call ended'
I have restored the phone to no prevail as well as trying other sims.
I would assume it has something to do with one of the phones IC chips? thought i would check before proceeding any further.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
That's an odd symptom...does the phone do anything else weird, especially regarding audio or antenna functions? Also, has the phone been physically damaged or repaired in the past?
Seeing as how you have already tried restring the device, it doesn't appear to be software related.
If the call just ends, that could be an indication that there is an issue with staying connected with the cellular network. You could try your sim card in another device or try a known-good sim card in yours. Otherwsie, there could be a logic board issue and the iPhone 7 has some very well documented issues with the Baseband CPU and Audio IC.
这个答案有帮助吗?
得分 2
添加一条评论
90% of the time when this happen on making or receiving calls it that your carrier has put a restriction between you and the towers either A) your just literally out of talk time or B) your SIM card needs to be replaced
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 5,032
