跳转到主内容
加入维修社区 - 创建账户
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
Suction cup won't adhere
Got my iFixit repair kit to fix a cracked digitizer on an iPad Mini 2. Instructions said to cover the screen in packing tape, but the suction cup provided does not adhere to packing tape -- not at all. Zero adhesion! So I'm stuck. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The cup will work! The tape you used was not laid down smoothly enough for the cup to grab and/or the tape was textured like duck tape.
Keep in mind you also need to apply heat to the display so the adhesive softens. I would apply the tape mostly in the middle leaving a small margin around the edges so you can get to the area where the display is adhered with a heat gun or iOpener without heating the tape directly as well as make sure I don’t create to many wrinkles in the tape for the better suction. Work on one side at a time and use the picks and/or cards to help hold the glass from re-adhering going in a clockwise direction.
To help in getting the cup to adhere you can apply a bit of petroleum jelly to the cup to help improve the seal. You’ll want to fully clean the cup afterwards as applying it directly to glass will leave a good mark which will be hard to clean off.
Don’t forget to wear safety glasses!!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brian Tate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 159
