跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
iPhone Battery Adhesive Removal
Hi, my adhesive strips have broken on my iPhone. I have been told that using some Acetone is a good way to dissolve the adhesive and remove the battery, without having to use heat or prying the battery. Is Acetone safe?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I really wouldn't recommend putting acetone in your phone. The best route is heat & pry. Anything is good, just don't get the phone too hot. If it's too hot to touch you've gone too far. But you can use a hairdryer, iOpener, heat gun, or even hold the phone near a hot (electric) stove. But don't try to dissolve the strips.
If you pry up at the edges of the battery (after heating) carefully you should be able to reach the adhesive strips again, and pull them out. I was replacing the battery on a 5s once and this is how I got it to work.
I hope this answers your question.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Donald 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,036
