Yes my tablet is asking for a pin number did not no it had one
Power your device off, and then start it up again and enter the correct pin number. If that doesn't work, you will need to try the option to enter your Gmail account credentials so that you can access your device and change your password.
If that doesn't work, do a Hard Reset by completing the following steps:
Turn off Tablet Try one of these key combos (each Android device uses a slightly different key combo, but these are the most common).
Volume Up + Home + Power Volume Down + Power Home + Power
or
look for a reset button/hole
Release the power button when you see the Android
Choose recovery mode
Choose wipe data/Factory Reset
Choose yes
Tablet will reboot or will ask you to reboot
NOTE: This procedure will delete all apps and data so use it as a last resort.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,457
