跳转到主内容
The second generation of the Samsung Gear, a round smartwatch running Samsung's Tizen smartwatch OS. The Gear S2 was released in October 2015.
72 个问题 查看全部
Won't charge. Says battery too hot.
I jumped in the pool with my watch on and found out it didn't like it. The screen flickered, but wouldn't come on. Using the tear down video and a 64 piece bit set both from ifixit, I was able to take the watch apart and let it dry out. After that I tried to charge it but got a triangle symbol message with a thermometer in it and it wouldn't charge. I left it off of the charger over night, then put it on the next day and it charged right up and behaved normally! Sadly, when the day was over and I went to charge it back up I got the same warning and it wouldn't charge. I employed the same method as before and it does charge after a few hours off the charger to "cool down"?? Has anyone else had this proiblem? If so, any advise?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
I have Three things to cover
*is the watch waterproof?
  • did you teardown the watch before you jumped into the pool?
  • did you see bubbles in the watch when your in the pool
Hope this was Helpful
这个答案有帮助吗?
得分 0
2条评论:
Or probably the battery got shorted and got hot.
完成的
添加一条评论
The watch is only water resistant for 1 meter. I thought it was more, but it also can have its water resistance "damaged" if you drop or impact it in any way. I have done both. My bad.
I never tore it apart until after the pool incident.
And I did notice the back of the watch fogged up after I noticed that it stopped working.
But a quick update, it had stopped giving me the error for a while now. Hopefully it continues to charge normally. It does seem to only last 10 hours now when it used to last around 18 hours.
这个答案有帮助吗?
得分 0
添加一条评论
Hi, i have exactly the same problem. Have you fix it ?
这个答案有帮助吗?
得分 0
添加一条评论
https://www.youtube.com/watch?v=Ocnh-DoN...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony Ramirez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 1,595
