跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
No graphics on built in display
I have this Mac that was given to me dead. I’m trying to fix and hopefully learn something in the process.
I figured out it had a bad video card so I replaced that and now it works perfect on an external monitor and it even detects the built in monitor but it will not display anything on it.
All 4 onboard diagnostic LED’s light up and the backlighting comes on but it is just a blank screen. The hard drive I put in it had Sierra on it which works great with external but maybe it doesn’t support the LCD?
I replaced the LCD just in case it had a problem with the same results. I will attach a pic of the system log because it will endlessly repeat the same thing and I don’t know what it means exactly.
I do have the Snow Leopard DVD but I can’t figure out how to get it installed.
Any help will be greatly appreciated!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Use a flashlight to shine into the display are you able to see the faint images of your desktop icons? If you are the LED driver board. If not the LVDS display cable needs to be looked at as well as the logic boards connection as you likely damaged it in the opening process.
这个答案有帮助吗?
得分 3
5条评论:
I cannot see anything with the flashlight and i have changed the lvds cable and inspected the connections very thoroughly without seeing anything wrong.
完成的
There's only the LVDS cable (and its connections) to the display or the display its self. So you'll need to check again as you missed something here.
完成的
It seems almost like it’s a software issue because i have swapped out every hardware piece that would be related (including logic board) with no change whatsoever. How can i get snow leopard on this drive? I cannot boot from the dvd even if i wipe HD clean. It just shows white page with crossed out circle.
完成的
You can try to turn around the display cable, that worked for me when i had similar issues
完成的
If he put the display cable in backwards on the logic board he likely blew the inductor and a cap! This would for sure stop the display from working.
完成的
添加一条评论
添加你的答案
egscomputers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 90
